Stock ecu boost??
Old Oct 23, 2016 | 08:21 PM
A.t.p's Avatar
A.t.p
Default Stock ecu boost??
I have just replaced my old stock worn out turbo with a new upgraded one! Probably What everyone would Call a stage 1.
After it was fitted the actuator (-31)
Was set Way to High, and the car would boost at around 12-13 psi (Got the AEM digital boost gauge)
The boost have been decreased, but the plan is to run 15 psi when the car is ready and when i have the money for a tune.
I thought that i had a Stock ecu and needed to get a chipped one, but as far as i know the stock ecu is not able to run that high of a boost level?
I believe that I've got a 90'spec ecu, but my question is, how many psi is possible on a stock ecu? Is it even possible to get 12-13 psi with a stock ecu? Or have my ecu been chipped by the previous owner? Would love to save a few hundred pounds on a tune!
Cheers😃
Old Oct 23, 2016 | 10:41 PM
martysmartie's Avatar
martysmartie
0.7 BAR (7 PSI)
Not sure what the boost cut is on RST.
I would want to be sure that it had been remapped, rather than risk melting an engine!
Martin
Old Oct 24, 2016 | 10:29 AM
A.t.p's Avatar
A.t.p
Originally Posted by martysmartie
0.7 BAR (7 PSI)
Martin
As I wrote, the boost have been decreased, it's back to 0,5 bar and I'm getting everything done by a tuner when the time comes.. I'm only interested in knowing if 12-13 psi indicates that my ecu is chipped? Or if it's possible to get that from a stock ecu?
Old Oct 24, 2016 | 11:52 AM
nigel b's Avatar
nigel b
10psi was the max you could run on a standard chip
