Obscure mondeo V6 queries
Old Oct 13, 2016 | 02:17 PM
alistairolsen's Avatar
alistairolsen
Default Obscure mondeo V6 queries
I have a few odd queries about the 2.5 and 3.0 mondeo gearboxes (MTX 75 I believe) if someone can help me out!
  • Can the equal length shaft be removed and a CV inserted in its place? It looks very tight for the bellhousing
  • Is the box cable shift?
  • I assume the clutch is hydraulic?
  • Does anyone know if the CVs (either inner or outer) are common with the other MTX75 boxes?
For a project, what I'd like to achieve is a short driveshaft into the engine side of the box, with a drive flange and wheelbearing on the end, ideally this sort of style:
Does anyone know if any front drive fords used such an arrangement and may have a compatible outer CV with the mondeo?
Cheers!
Old Oct 13, 2016 | 02:35 PM
alistairolsen
Mk7 transit has a suitable looking wheelbearing
I believe they used an MTx75 box too?
Are the inner CV joints common?
Old Oct 13, 2016 | 02:39 PM
alistairolsen
Ebay suggests the outer CVs are completely different, as are the driveshaft splines
Transit:
http://www.ebay.co.uk/itm/FORD-TRANS...gAAOSw4shX4SxO
Width: 120mm Manufacturer Part Number: CV1016N Diameter: 101mm MPN: CV1016N External Teeth, Wheel Side: 28 EAN: 5054259083012 Seal Diameter: 60mm Part Manufacturer: Shaftec Internal Teeth, Wheel Side: 29 Weight: 3610g Overall Height: 200mm Length: 260mm Number Of Teeth, ABS Ring: 48 Height: 120mm ABS Ring Diameter: 104.5mm
Mondeo ST220
http://www.ebay.co.uk/itm/Ford-Monde...QAAOSwqBJXU3ZC
Diameter (mm): 91 Seal Diameter (mm): 53 Height (mm): 155 Internal Teeth Wheel Side: 26 External Teeth Wheel Side: 27
Cauf61
Sep 4, 2016 07:03 PM
RSMK4TURBO
Aug 11, 2016 09:18 PM
B16CVH
Ford XR Parts For Sale
Jul 30, 2016 03:46 PM
Shaunc
Jul 28, 2016 09:09 AM
Smiler
Jul 18, 2016 09:19 AM
