Starting problem Help please
Old Oct 3, 2016 | 08:10 AM
BMrider's Avatar
BMrider
Default Starting problem Help please
Ford Sierra Sapphire 2.0 DOHC manual 1989
Trying to get engine to crank
Fitted brand new battery 72Ah tested and fully charged
On trying to crank engine nothing!
Off load volts on battery 12.8V
Turn key drop to 10.8V and then recovers
There is a noise from alternator when turning ignition key and if I place my hand on the alternator a vibration can be felt
any suggestions please!
Thanks
Old Oct 3, 2016 | 08:15 AM
RichieST's Avatar
RichieST
Maybe the alternator has siezed? Take all the belts off and see if the pulleys turn freely. Or even try turning the engine over by hand.
Old Oct 3, 2016 | 09:35 AM
BMrider's Avatar
BMrider
Thanks but the engine / alternator can be turned by hand ok,
Old Oct 3, 2016 | 09:54 AM
RichieST's Avatar
RichieST
Have you checked the voltage at the starter while cranking? If it has 12v then drops right off it when cranking it would suggest an earth problem.
Old Oct 3, 2016 | 10:25 AM
BMrider's Avatar
BMrider
OK, just run the battery over to auto electrician, although its brand new you don't know how long these flat post batteries have sat on the shelves unsold, however it checked out fine on a drop test.
The problems sorted though, it was the starter / solenoid, shorting main power feed to solenoid connection a few times coxed it into life, its spinning over on the key like a gud-un now, now onto the next problem!
Thanks for all the help
Jack and the Beanstalk
Jan 14, 2017 05:47 PM
Cauf61
Sep 4, 2016 07:03 PM
lionrat
Jul 31, 2016 06:45 PM
Jul 26, 2016 05:29 PM
loggie
Jul 21, 2016 04:59 PM
