CVH Engines
Old Sep 23, 2016 | 02:32 PM
428cj's Avatar
428cj
Default CVH Engines
Bit of a newbie to small block ford engines...looking for advice on the old CVH engine.
1. what is the largest oversize piston available to the 1.3/1.6 block and who would be the best supplier
2. I have a NOS Crosshatch 1.3 head here...would be it feasible to have that head ported and polished to fit a 1.6 engine (Have the ports enlarged to the 1.6 size)
3. Do they still supply solid lifters for these engines?
Lastly, how would you increase the compression ratio on these engines?
Would like to have at least 10:1
Look forward to hearing from the CVH gurus.
Old Sep 23, 2016 | 02:46 PM
haz87's Avatar
haz87
Available from Newman as complete cam kits.
10:1 is absolutely achievable, head skim will do the trick with plenty of meat left
Old Sep 23, 2016 | 02:51 PM
428cj's Avatar
428cj
Thanks a bunch for that...I haven't done much with the hemi style engines...was worried about the valves making contact with the pistons....any idea as to how much I would need to remove to get 10:1??
Cheers and thanks again when using a higher lift cam....
Old Sep 23, 2016 | 03:11 PM
haz87's Avatar
haz87
I honestly cant remember what i removed to get 11:1 - however whoever does the machine work should be able to measure/calculate for you.
As for piston size, +1mm was easily attainable, i believe you could go as far as +1.5mm (or maybe 1.25) but it was really not a good idea as the walls were getting v.thin at that point.
I ran +1mm pistons, decent compression, high lift solid cam, top spec head, fully balanced and blueprinted bottom end - would regularly hit 8k rpm on one of my old n/a cvh's - loved it!
Old Oct 15, 2016 | 09:12 PM
428cj's Avatar
428cj
Have a 1.6 CVH block here...bored + 050"....where can I buy + 060" pistons???
Thanks in advance.
Old Oct 16, 2016 | 09:34 AM
Try www.burtonpower.co.uk
Old Oct 16, 2016 | 10:43 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
i doubt it's bores 0.050" as it's not a standard oversize. it may well be 0.50mm though? 1mm oversize should be readily avaiable if so
Old Oct 20, 2016 | 04:23 PM
428cj's Avatar
428cj
Default CVH 1.6 Block
Think it is more practical to find a standard 1.6 block and bore out for new pistons...anyone have a std. 1.6 Block for sale???
jonfoc
Ford Focus RS Parts for Sale.
Oct 12, 2016 06:03 PM
markie t
Sep 10, 2016 05:41 PM
Viniii
Sep 8, 2016 04:32 AM
jimmcnic
Sep 5, 2016 11:33 PM
rob w
Sep 5, 2016 08:59 PM
