Dump valve removal?
Old Sep 16, 2016 | 04:34 PM
B11GNS's Avatar
B11GNS
Default Dump valve removal?
Hi. My mk2 rs has a forge dump valve fitted which replaces the symposer hose with a T hose. I want to put it back to standard so I need the red hose in this picture
I haven't got this hose but I have one from an st which is the same shape but it's a black hose instead of the red colour
Can I use this black one or will o have to try to get the proper red one?
Old Sep 16, 2016 | 05:27 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
As long as it holds boost pressure then it will not matter.
Old Sep 16, 2016 | 05:39 PM
B11GNS's Avatar
B11GNS
That's the thing it's off an st so physically it will fit but the st obviously has lower boost levels then the rs so unsure if it will be ok.
Old Sep 17, 2016 | 08:27 AM
Caddyshack's Avatar
Caddyshack
10 Year Member
I am sure it would take 5 times the standard boost, you can't damage the engine if it fails so give it a go.
Old Sep 17, 2016 | 08:46 AM
B11GNS's Avatar
B11GNS
That makes sense. It's just a bit odd that ford would make the same part out of different material for the rs if the st part was good enough anyway.
AndyStarks
Escort Range
Dec 29, 2016 10:14 PM
Mondi-DZK
Sep 19, 2016 06:53 PM
fraz11
Sep 15, 2016 08:29 PM
dickdastardley
Escort Range
Sep 14, 2016 12:35 PM
jdsjojo
Sep 10, 2016 08:44 PM
