Mondeo 52 key -Heelpppp
Old Sep 5, 2016 | 03:15 PM
richardmoorenet's Avatar
richardmoorenet
Default Mondeo 52 key -Heelpppp
Hi, I have lost (mislaid) my Key for my Mondeo TDCi 52 reg. Problem is it was the only one I had
I believe I am right in saying it's a trip to Ford so they can relieve me of £160 ?
I saw on ebay you can buy 'uncut' ones but I guess that is no good to me as I don't have a spare.
I also read that it is possible to re-code a key yourself (see below)
But again as I lost the only key, assume that is not an option either ?
To set the code:
With the key in the ignition, turn the ignition on to the I position, then off and then again three times, then once more and leave it at I (a beep will sound showing that the system is set to program).
Now press the unlock button on the remote (press the unlock button on any other remotes that you have to program at the same time).
Now turn the ignition off (a beep will sound indicating that program mode is finished).
Old Sep 5, 2016 | 04:32 PM
STeve's Avatar
Super Moderator
quality auto locksmiths can also do what dealers do
Danielbetty
Mar 14, 2016 10:55 AM
Hurlow66
Mar 5, 2016 08:40 PM
Rob Winstanley
Ford Focus Range
Mar 2, 2016 06:50 AM
bassboy
Feb 26, 2016 03:09 PM
willos90
Feb 26, 2016 07:52 AM
