Ford Focus ST Parts for Sale Only Ford Focus ST parts here please. Register for a Gold Membership to list!
X2 ST170 engines for sale. X1 98k & X1 fully rebuilt
Old Jul 29, 2016 | 05:29 PM
Tank Mike's Avatar
Tank Mike
Default X2 ST170 engines for sale. X1 98k & X1 fully rebuilt
Due to going forged/ hi comp my rebuilt engine and spare running engine are for sale.
Engine 1
Covered 98,000 miles. Ran fine although I would recommend a Cambelt change. £175.00
Engine 2
Started as a 68k running ST170 engine, completely stripped down, everything measured. Has STD grind crank (fully plastigauged) with new big end shells, piston rings (measured and gapped), ARP rod bolts, genuine ford head gasket, all new seals and gaskets, new stem seals, valves de carboned and re ground in, valve clearances re done, new Gates Cambelt kit. I have a lot of photos from the build up I can send out, but need to get over the garage to take some pictures of the finished item £500.00 (engine will require running in)
Both located in Staines (J13/M25)
07985266042
Old Jan 1, 2025 | 09:45 PM
BIG LEE's Avatar
BIG LEE
2016 🤷‍♂️....
Tank Mike
Sep 10, 2015 07:56 AM
Big Will_
38
Jan 18, 2012 06:05 PM
hughsie
Ford Focus ST
Jun 24, 2011 11:30 PM
Oranoco
Nov 22, 2008 07:24 PM
