can cvh big end bolts still be bought?
Hi guys i've been searching all morning and rang my local ford stealer (completely useless)
I'm looking to give the bottom end of my turbo converted cabbie a refresh due to suspected big end knock I've got a full gasket kit, head gasket, head bolts and all new exterior bolts. the only thing I need now is rings, bearings and bottom end bolts.
The bearings and rings will be bought when i've stripped the block and know the sizes needed I also know the main cap bolts are easily sourced however all I can find is arp big end bolts I'm not going for big power just want a refreshed engine.
did you try with www.motomobil.com
maybe here you can find the rod and crankshaft bearings...
http://www.motomobil.com/products,32...&q=cvh&latest=
