Zoo Motorsport Rosejointed/Adjustable Front Suspension/Compression Struts
Old Jul 18, 2016 | 09:12 AM
B16CVH's Avatar
B16CVH
Default Zoo Motorsport Rosejointed/Adjustable Front Suspension/Compression Struts
PROVISIONALLY SOLD
Hi all,
Having a bit of a clear out and the above is now up for sale.
Up for sale is a fully rose jointed and adjustable front suspension setup in as new condition for a Mk4 ERST manufactured by the modification legend Brom at Zoo Motorsport.
Parts consist of;
* Custom front mounting plates which replace the existing std ones (the two which hold the std roll bar) which incorporates a towing eye screw in location which is supplied also. Newly powder coated black
* Custom bladed roll bar with 2Nr double width ARB poly bushes. Newly powder coated black
* 2Nr custom tension struts rose jointed at one end with in-situ adjusters and a tag at the other to connect to the TCA cone. Newly powder coated black
* 2Nr NEW rose jointed drop links (4 rose joints in total) to connect the bladed roll bar to the tension struts.
* 2Nr NEW cone links to connect the tension struts to the TCAs (Not included)
* All new nuts/bolts.
This kit makes a massive difference to the handling of any Escort and you will be amazed at the difference. You don't need to modify your chassis in any way just a straight swap.
This cost around £600 from memory to have made, looking for £395 and collection only due to size/weight unless you want to arrange your own courier and so i may be able to package up somehow.
Attached Thumbnails Zoo Motorsport Rosejointed/Adjustable Front Suspension/Compression Struts-20160718_174941.jpg   Zoo Motorsport Rosejointed/Adjustable Front Suspension/Compression Struts-20160718_173908.jpg   Zoo Motorsport Rosejointed/Adjustable Front Suspension/Compression Struts-20160718_174946.jpg   Zoo Motorsport Rosejointed/Adjustable Front Suspension/Compression Struts-20160718_174948.jpg
Old Jul 18, 2016 | 07:39 PM
cossirob's Avatar
cossirob
Would this fit a s1 rst?
Old Jul 18, 2016 | 07:55 PM
B16CVH's Avatar
B16CVH
If the bolt pattern for the original ARB mounts are the same then yes it should fit. I'm sure somebody on here will be able to clarify for sure.
Old Jul 26, 2016 | 08:01 PM
B16CVH's Avatar
B16CVH
Now SOLD
anthony lea
Apr 7, 2016 06:01 PM
Rs(555)
Feb 28, 2016 08:31 PM
M K
Feb 26, 2016 11:44 AM
muz
Feb 22, 2016 08:27 PM
