Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Focus mk2 bi-xenon rating.
Old Jul 13, 2016 | 09:49 AM
James Brunt's Avatar
James Brunt
Cool Focus mk2 bi-xenon rating.
Hi there,
I purchased a 2009 Ford Focus Titanium 2.0 tdci yesterday and I am very pleased with it. I went for a drive at night at thought that the Bi-Xenons were very underwhelming as I had especially looked for a car fitted with them. I assumed that the bulbs were getting old but after reading the user manual they are only listed as 35W bulbs.
My question is can I upgrade the bulbs to 55W ones? I have the headlight washers and auto-leveling so cannot see any reason why I couldn't. Would I need to replace the ballasts?
Thanks
James
Old Jul 13, 2016 | 10:53 AM
STeve's Avatar
Super Moderator
the xenon K range normally on a standard ford xenon bulb is approx 3500k-4500k the brightest white is 6000k then anything over that give a blueish tint but all will work but oersonally I would not go over 6000k
Old Jul 13, 2016 | 05:49 PM
James Brunt
Thanks for your reply. I would probably go for 6000K bulbs but my question is can I fit 55W 6000K bulbs as apposed to 35W 6000K bulbs?
If I fit the 55W 6000K bulbs will I need to change the ballasts?
Thanks again, James
Old Jul 13, 2016 | 06:02 PM
RichieST's Avatar
RichieST
Yes you will need to change the ballasts as the higher current draw from the bulbs will burn them out. You may find 55w bulbs won't work anyway as the ecu may think the extra load is going to ground and shut the circuit down.
The xenons in my old mk2 st were brilliant. Maybe just try a new set of standard bulbs.
capri-rs
Mar 14, 2016 01:30 PM
Danielbetty
Mar 14, 2016 10:55 AM
zepp_mt
Mar 8, 2016 06:55 AM
Vesty
Mar 4, 2016 05:43 PM
Rob Winstanley
Ford Focus Range
Mar 2, 2016 06:50 AM
