rs turbo intercooler
Old Jul 5, 2016 | 06:43 PM
MARKYMARKONE's Avatar
MARKYMARKONE
Default rs turbo intercooler
Hi
Ive got a s2 rsturbo which is running a 2.1zvh, with front mount intercooler, 2 cooling fans then the radiator.
In this set up the coolant runs very hot it goes past 110/120 degrees on the after market gauge in traffic.
Its running a 82degree thermostat and uprated switch, uprated / rebuilt radiator.
Im guessing my issue is down to the front mount intercooler blocking the air flow, so im tempted to put my standard intercooler back on and try it.
Does anyone know what boost the standard intercooler can take?
Or any ides how to low my temp
Mark
Old Jul 5, 2016 | 06:52 PM
Caddyshack's Avatar
Caddyshack
What front mount do you have? You might just need a better one, a good fan and good fan controller.
Old Jul 5, 2016 | 07:13 PM
MARKYMARKONE
Im not sure on the make of intercooler or fans
Old Jul 5, 2016 | 07:38 PM
muz's Avatar
muz
Wye Valley Hardcore
If a front mount cooler is causing you overheating problems then your problem lies elsewhere. Old radiator, water pump, coolant mix, heater matrix etc.
Old Jul 5, 2016 | 08:09 PM
MARKYMARKONE
Radiator, water pump, heater matrix, thermostat , temp sensor, head gasket have all been replaced and still the same
Old Jul 5, 2016 | 08:14 PM
muz's Avatar
muz
Wye Valley Hardcore
Are you running twin fans on the old fan loom?
Old Jul 5, 2016 | 08:39 PM
MARKYMARKONE
Yes twin fans on old loom
Old Jul 5, 2016 | 08:49 PM
muz's Avatar
muz
Wye Valley Hardcore
That might be the problem. If the wiring is old and creating resistance the volt draw will be too much and the fans won't spin as quickly so they won't be cooling properly.
This has a massive impact on the speed which the fans will operate. My fans kick on and off quickly but I remember disconnecting the alt belt to work on the car and running it up to temp and thinking the fans had been on ages without switching off and the battery had only lost half a volt running the fans but they just weren't cooling enough. Belt back on and started it up and the fans sounded like they were running at twice the speed immediately.
Old Jul 6, 2016 | 02:36 PM
RSmark84's Avatar
RSmark84
This is what you want.
http://www.ebay.co.uk/itm/Ford-Escor...sAAOSwBw5XRGGK
Also you can fit over-rider switch/es to the fans too.
Old Jul 6, 2016 | 08:13 PM
nigel b's Avatar
nigel b
thats an expensive bit of wire,is it gold plated?
overide switches are not needed if your cooling system works well
your intercooler wont affect the cooling with the fans
are you sure the aftermarket temp guage is correct?
Old Jul 6, 2016 | 09:56 PM
MARKYMARKONE
Dash temp shows up in the red and this is the second after market gauge.
Could it be the way its been set up? Wrong fueling etc?
Mark
Old Jul 6, 2016 | 10:08 PM
muz's Avatar
muz
Wye Valley Hardcore
If it's running lean it will run hot. I'd still be checking the resistance of the fan loom.
Old Jul 6, 2016 | 10:22 PM
nigel b's Avatar
nigel b
what temp are you getting on normal cruising?
has the car been set up at all
Old Jul 7, 2016 | 08:08 PM
MARKYMARKONE
Car was set up on the road, its running ofam.
Normal temp is around 90 ish but in traffic it struggles to cool down. Ive noticed the fans cut in and seem to stay in
Old Jul 7, 2016 | 08:37 PM
nigel b's Avatar
nigel b
wire your fan switch to a relay
power the fans off the relay
Old Jul 11, 2016 | 06:45 PM
studabear's Avatar
studabear
Are the fans turning in the right direction?
bailey1
Apr 12, 2023 08:17 PM
shanek2041
Apr 23, 2016 06:25 PM
Andyrangy
Apr 22, 2016 07:10 PM
Tank Mike
Ford Focus (All Models)
Apr 8, 2016 02:37 PM
