Cosworth parts for sale
Old Jun 28, 2016 | 02:06 PM
richard caine's Avatar
richard caine
rs enthusiast
Default Cosworth parts for sale
Sierra Cosworth twin fans.
These fans are in used condition, with the connectors and wiring attached.
http://www.ebay.co.uk/itm/Sierra-cos...e=STRK:MESE:IT
A rear washer bottle and pump from a 3 door sierra cosworth/RS500
This part is in used condition.
http://www.ebay.co.uk/itm/3-door-cos...e=STRK:MESE:IT
A power steering reservoir from my sierra cosworth. Its made by "Pace Products" in Alloy. The top has a billet turned aluminium cap, with the pipe connections being 16mm O.D. & 12mm O.D. with swages for the pipes and clips to locate.
This part is in used condition, and has surface scratches. Its made from aluminium so you can polish it to a mirror finish.
http://www.ebay.co.uk/itm/Cosworth-P...e=STRK:MESE:IT
A pair of Sierra Saphire, Cosworth, 4X4, Smoked Rear Lights
These lights are in good used condition, and come with the bulb holders and the neoprene foam backing. All of the fixing studs are in place. These lights are smoked finish. The bulb holders have scuffing from the wear and tear of items rubbing them in the boot area.
http://www.ebay.co.uk/itm/Sierra-Sap...e=STRK:MESE:IT
A catch tank from an RS cosworth Can be used on any car. It is Alloy welded and has a powder coated finish. It is in used condition.
Has 3 off 17mm diameter pipe connection points with swages to secure the pipe clips.
The tank dimensions are 115 mm diameter x 135 mm high.
The capacity of the tank is 1.0 litre (approx).
Has a mounting point for fixing to the car.
The powder coating colour is black
http://www.ebay.co.uk/itm/Cosworth-R...e=STRK:MESE:IT
A 16 row oil cooler (50mm x 190mm x 360mm core)
This cooler has never been used. It has 2off 3/4bsp pipe fillings.
http://www.ebay.co.uk/itm/Oil-Cooler...e=STRK:MESE:IT
alistairolsen
Mar 14, 2009 06:20 PM
Dingy
Sep 21, 2007 02:19 PM
Chip
Sep 19, 2007 03:56 PM
woodz77
Dec 30, 2006 12:22 PM
Mike Rainbird
32
Sep 22, 2006 02:06 PM
