Upgrading reverse bulb on st170
Old Jun 7, 2016 | 07:27 PM
beller's Avatar
beller
Turb
Default Upgrading reverse bulb on st170
Hi, as above really
I tried these super bright 24 led bulbs with the resistor....the resistor got hot but bulb wouldn't light up, so they sent me another and again nothing.
Will led's work in the reverse light fitting?
or can I get brighter standard bulbs (is it 21w standard)
Thanks for any comments or suggestions
Old Jun 8, 2016 | 05:30 AM
STeve's Avatar
Super Moderator
the reverse & foglights on the 170 are all wired up back to front with a positive earth, so only way to fit led style bulbs is to reverse the polarity as I have 2 reverse led lights on my 170
Old Jun 8, 2016 | 11:54 AM
beller's Avatar
beller
Turb
That's great info mate thanks, makes sense now.
So did you just wire the LH reverse from the right hand reverse wires?
Old Jun 8, 2016 | 04:14 PM
STeve's Avatar
Super Moderator
as I break 170s I simply cut the loom on a donor car and made a patch lead reversing the wires taking the feed from the left and simply running reversed wires to left & right with correct polarity, the foglights in the front are also wired arse about face too
Old Jun 8, 2016 | 07:43 PM
Im after the oposite. I want a nsr fog light lense instead of the reverse lamp.
Old Jun 8, 2016 | 08:38 PM
STeve's Avatar
Super Moderator
thats easy to do also glenn
Old Jun 9, 2016 | 01:04 AM
beller's Avatar
beller
Turb
Thanks again 1-PD
BigD.
12
Jun 4, 2016 03:31 PM
JoeyBoyden
May 26, 2016 06:29 AM
Fudgey
18
May 24, 2016 08:42 PM
RSmark84
May 10, 2016 07:09 PM
B13 JUS
May 9, 2016 04:45 PM
