Cutting off donor front wings - good idea?
Old Jun 4, 2016 | 09:12 PM
Dennis_Wiseman's Avatar
Dennis_Wiseman
Default Cutting off donor front wings - good idea?
As you can't buy genuine front wings for a mk4 Escort, has anyone attempted to drill and cut off genuine wings from a donor or is this a bad idea ??
If its a non starter, can anyone recommend decent fitting replica wings?
Old Jun 4, 2016 | 11:10 PM
Nosmonkey's Avatar
Nosmonkey
I've done it on a few cars albeit not on an Escort. Decent spot weld drill bit makes short work of spot welds. Make sure you get the ones that are similar to a milling drill bit but makes a pilot hole (or in non technical terms, a small pointy bit then is then kind of flat), I wouldn't bother with the ones that look like small hole cutters. Chisel/old screwdriver into where the spot weld was between the two panels and then give it a good whack with a hammer, repeat for all the spot welds and jobs a good 'un.
Old Jun 6, 2016 | 07:12 PM
moe197t5's Avatar
moe197t5
I have took nearly a full mk 3 shell apart before now to get the panels use spot weld drill bits as above but its a long task and depends what else you wanna save
Old Jun 6, 2016 | 08:19 PM
Dennis_Wiseman
Just after genuine wings as the car has been running motor factor items for the past few years and the fit is terrible.
Been told by someone its not the best idea removing as its easy to twist / kink the wing.
Old Jun 6, 2016 | 09:13 PM
botters's Avatar
botters
competant bodger
wings are pretty straightforward to remove
JC600
246
Feb 5, 2018 10:10 PM
rs-saint
34
Jan 24, 2018 01:19 PM
Trev_rev
Nov 1, 2016 04:15 AM
cutch
May 2, 2016 05:55 PM
brainz94
Mar 25, 2016 08:06 AM
