Removed this from my 1990 4x4 Cos a few months ago and now can't remember where it came from. I believe it was somewhere around the battery area of the engine bay. It is made of rubber or foam. Thanks David
Hmmm. Wouldn't have thought I would have taken it out from there as I did not have the scuttle panel off. Do you think there is another similar one in by the wing somewhere. Like I said I don't have the car at work so can't look till I get home. Thanks again David
Sweet I've had that piece sitting in me draw for about 10 yrs I also couldn't see where it came from!! Also notice from the pick the Rubber U channel on the front of the scuttle panel? I don't have that on mine, what's it for?
Thanks Paul. Finally got around to having a look at the car tonight and that is exactly where it came from. Blocks off the end of that cavity and in my case the notch in the bottom appears to be for a wire which I am guessing is for the heated washer jets although I haven't followed it to confirm. Thanks again David.
