T3 Conversion oil return stubs made to order
A must have if your doing a T3 conversion on your Fiesta RS Turbo, as when carrying out this conversion you need to change the Fiestas oil return stub with the Escort one. The genuine items are very rare to come across so I have machined this item ( can be seen below) which is cheaper and better than the original item as the "rats tail"on the end of the fitting will the hose more grip on to the stub. If you want one pm me and I will machine one up for you as soon as I can
£20
£20
paceo
Mar 23, 2016 05:28 PM
kevin micallef
Mar 6, 2016 05:36 PM
