Thermostat sensor
Do you mean the fan switch?
http://www.ebay.co.uk/itm/Radiator-F...kAAOSw7aBVHOjY
http://www.ebay.co.uk/itm/Radiator-F...sAAOSwv0tVHIMR
I can't see any difference other than colour and price.
You could get an uprated switch which will switch the fans on earlier. But does require the old loom plug to be cut off and two spade connectors put on the two loom wires.
http://shop.motorsport-developments....rated-43-p.asp
