Long Studded RS500 Block
Old May 8, 2016 | 06:00 PM
jonny-boy's Avatar
jonny-boy
Default Long Studded RS500 Block
Hello all.
here we have my rs500 block that I bought a while ago for a big build but has stood in the garage. The block has just returned from Cleasby Precision Engine Services where it was fully checked over and cleaned internally and externally and prepared ready to build up, they commented its a "used but as new block" on standard bore. The block has had the inner 6 bolt holes long studded, so will need no preparation to build a big bhp engine.
£2500 or very close offer thanks
Attached Thumbnails Long Studded RS500 Block-rs500-block-786.jpg   Long Studded RS500 Block-rs500-block-787.jpg   Long Studded RS500 Block-rs500-block-788.jpg   Long Studded RS500 Block-rs500-block-789.jpg   Long Studded RS500 Block-rs500-block-791.jpg
Old May 8, 2016 | 06:31 PM
Caddyshack's Avatar
Caddyshack
Is the rs500 block different to the basic 205 block then as normally people go for the 200 block.
Nicely presented by the way
Old May 8, 2016 | 06:37 PM
800bhp's Avatar
800bhp
**RS COSWORTH**
10 Year Member
I maybe wrong but as far as I know Rs500 205 blocks are the 200 blocks that were later fitted to the Escort Cosworth.
Old May 8, 2016 | 06:49 PM
jonny-boy's Avatar
jonny-boy
Hi the rs500 blocks were considered the ultimate block they have thicker walls smaller core plugs than the 200 blocks and the sapphire 205 blocks and were run in the 560 bhp touring cars back in the day. They are very heavy/stronger compared to the later 200 and 205 blocks
Old May 8, 2016 | 07:04 PM
Caddyshack's Avatar
Caddyshack
Wow, thanks for the info. I am researching blocks for a rebuild
Old May 8, 2016 | 07:05 PM
Caddyshack's Avatar
Caddyshack
Odd they didn't give them a new code like a "500 block"
Old May 8, 2016 | 07:08 PM
jonny-boy's Avatar
jonny-boy
202-pinto/transit block
205 small core plug-rs500 block with thicker walls
205 large core plug-2wd sapphire cosworth block
200-escort cosworth block thicker material around base area to accept 4wd running gear
Old May 9, 2016 | 12:29 PM
Adam-M's Avatar
Adam-M
I always thought the rs500 block was the same strength as the 200 block?
Old May 9, 2016 | 04:51 PM
jonny-boy's Avatar
jonny-boy
Over the years(12 with an escort cosworth) I have weighed the bare blocks as follows:
205 is 43.9 kg
200 is 48.1 kg
Rs 500 205 block is 49.2 kg
Old May 9, 2016 | 04:53 PM
jonny-boy's Avatar
jonny-boy
Plus they didnt have cracking issues unlike the escort cosworth 200 blocks
Old May 9, 2016 | 05:12 PM
jonny-boy's Avatar
jonny-boy
There are no numbers on the block so can be stamped to suit the car
Old May 11, 2016 | 08:21 PM
adam151082's Avatar
adam151082
Interesting, ive got a RS500 block in my car. Good luck with the sale.
Old May 15, 2016 | 03:29 PM
jonny-boy's Avatar
jonny-boy
Listed on the bay now 272243926930 Thanks
Old Jun 19, 2016 | 08:20 PM
jonny-boy's Avatar
jonny-boy
Bump Bump
Old Jul 17, 2016 | 07:13 PM
jonny-boy's Avatar
jonny-boy
£2200 Now
Old Jul 17, 2016 | 07:14 PM
jonny-boy's Avatar
jonny-boy
contact : jlee@matherandstuart.co.uk because I don't come on here much now with limited internet
Old Sep 2, 2016 | 04:59 PM
jonny-boy's Avatar
jonny-boy
Bump me up I'm still hear
Old Sep 14, 2016 | 07:15 PM
jonny-boy's Avatar
jonny-boy
NOW SOLD
The Black Count
Sep 21, 2017 01:48 PM
M K
May 8, 2016 03:48 PM
voodoo333
Ford Focus Diesel
May 8, 2016 12:02 PM
JoshXR2
May 2, 2016 05:37 PM
