Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
mk3 mondwo zetec tddi not starting
Old May 2, 2016 | 10:20 PM
patrick27's Avatar
patrick27
Default mk3 mondwo zetec tddi not starting
hi i have mondeo mk3 tddi with 77000 mile had car for 2 saus now driving fine without problem till now went to the shops and drove fine on way back the car kangarod a bit so turned engine off mow wont start have greenflag come out and it started with easy start then cut out so he took the fule pipes off filter and turn car over and no fule came out of the pipes and all he said u got blocked pipe what do u fink the problem can be thanks
Old Nov 3, 2016 | 05:38 PM
R4N SS's Avatar
R4N SS
change the fuel filter mate
Old Nov 3, 2016 | 05:47 PM
16imarty's Avatar
16imarty
The tddi have a pump near fuel tank that probably worn out give it a tap see wot happens
Old Nov 3, 2016 | 07:27 PM
RichieST's Avatar
RichieST
wiggle the wiring to the high pressure pump. I had a broken wire here on my old one.
Brickhouse
Ford Mondeo Including ST
Oct 23, 2019 10:51 PM
scott-UK
Ford Fiesta
Jun 12, 2016 08:05 PM
minder
May 25, 2016 05:14 AM
Gadget
Apr 24, 2016 08:11 AM
Mk6fez
Apr 3, 2016 05:09 PM
