Door loom rubber sleeves
When I built the Orion up I found good loom rubber sleeves that go from a, bc posts to the doors ( the bit where the looms run through into the doors )
I've noticed one is starting to split again, I think I've got a couple spare somewhere, but is there new replacements available from anywhere, or a alternative to genuine parts? As I'm sure you can't buy them seperate and it comes with the door looms from Ford...
