Cosworth parts for sale all in good working order.
Cosworth 2wd Motorsport Developements -31 Wastegate Actuator - couple of years old unused £50
Stainless Steel Coil Cover £15
Standard 2wd Bosch Dump Valve & Hose £30
Stainless Turbo Water Pipes, think these are off of an escort cosworth, came with a turbo i bought a few years ago £25
Ahmed Bayjoo L6 330bhp Chip & A Set Of 4 Dark Green 803 Injectors - came off my car a few years ago due to upgrade, chip is for 2wd std compression, 803 dark green injectors, T3 Turbo, 3 bar map sensor, large intercooler, make sure fuelling is correct and must use vpower or equivalent 97 RON or higher petrol with it. £150
Turbo Technics T34 .63 Exhaust Housing £170
T3 Wastegate Actuator Bracket £10
Oil Pressure Adapter £10 Each - pressure switch might not work.
All items plus charges + postage and open to sensible offers.
Reason: Some parts are sold
I want the t34 turbo damper plate, plus postage via courrier service to Greece cause I want it within the next couple of weeks.
Please pm me your paypal details and total cost.
.63 turbo housing now £150 posted mainland uk.
-31 £50 posted mainland uk as well
Someone buy them so i can get my engine rebuilt, damn 205 blocks and head bolt holes cracking.....
If it's in the garage it's either broke or raining..
It has one hairline crack on the inside where the housing bolts to the turbo core as seen in the picture, i will take a better picture of it later, it came off my T34 so it will fit.
