Rst dizzy, Webber crank triggers and bits
Old Apr 3, 2016 | 04:43 PM
Gadget's Avatar
Gadget
Spanner monkey
Default Rst dizzy, Webber crank triggers and bits
Just clearing out some bits..
Perfect rst dizzy
Getting rare for a nice one now, unbroken plug £30 delivered.
1800 cvh bottom pulley with trigger wheel modded for Webber management
£25 delivered
Efi flywheel modded for Webber management, has 4 pickups on the back in the correct position to use sensor in the block. Skimmed ready to go.
£50 delivered
Cvh crank trigger kit, bracket bolts to the sump using 2 sump bolts.
Came off xr2 turbo. Freshly re painted, full kit £65 delivered
Mfi to efi adapter plate £50 delivered
Nice steering wheel, no boss, £20 delivered
Weld on crank trigger disc £20 delivered
Cvh cam trigger bracket and sensor £20 delivered
Erst crossover pipe with sensor £20 delivered
Frst crossover pipe, slightly shortened £20 delivered
Frst crossover pipe modded to fit escort with temp sensor hole £20 delivered
Reverse Frst crossover pipe with temp sensor thread and dump valve take off £35 delivered
Race tech volt guage, carbon plate and push switch, £25 delivered
Please call or text me, Gary 07946367994
Old Apr 6, 2016 | 07:31 PM
Gadget's Avatar
Gadget
Spanner monkey
Crank trigger kit and Escort crossover pipe sold.
Old Apr 17, 2016 | 10:55 AM
214_si's Avatar
214_si
U have pm
Old Apr 24, 2016 | 08:11 AM
Cossy Mike's Avatar
Cossy Mike
I'll have the dizzy, PM your details
3doorcozmess
Feb 15, 2016 09:43 PM
zetec-s81
Feb 12, 2016 08:00 PM
kyam786
Feb 10, 2016 02:36 PM
timsrs
Feb 8, 2016 12:41 PM
Hannah Elizabeth
Jan 27, 2016 09:44 PM
