Boost question
Old Mar 29, 2016 | 07:53 PM
Ellsa's Avatar
Ellsa
Default Boost question
Hi guys I'm Nearing the end of my erst build it runs spot on but it doesn't sound like a turbo as if there's no boost when I Rev it , so reluctantly I fitted a dv to see if whom tooshed nothing boost gauge is just showing vaccum only the waste-gate in the housing was pretty stiff so I changed it for another witch moved freely still nothing I've looped the turbo bleed valve Amal valve nothing changes only thing I can think of would be the actuator itself is a -31 from a cosworth and I never bothers changing the length in it ? Is there any difference ? I'll await the sarcastic comments
Old Mar 29, 2016 | 08:01 PM
martysmartie's Avatar
martysmartie
It will only produce boost under load, revving it will do nothing.
Martin
Old Mar 29, 2016 | 08:06 PM
Ellsa's Avatar
Ellsa
Thanks Martin I get that I really do but I have seen rs turbos rev and produce dv noise stationary ? Is there a reason for this
Old Mar 29, 2016 | 08:39 PM
martysmartie
I guess a lot of it is down to the spec, engine and turbo choice being the two big factors. A T3 is a large turbo to spool up for your engine.
Martin
Old Mar 29, 2016 | 08:56 PM
Ellsa's Avatar
Ellsa
So as follows I have , lighten and balanced crank , stress relived con rods , and make low comp Pistons , gas flowed big valve head , piper 285t2 cam , t3 turbo with t34 compressor wheel and 360 degree bearings , -31 actuator , baileys dump valve (don't work) , mocal oil cooler the list goes on
Old Mar 29, 2016 | 09:00 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
If you are running a twin piston dump valve you need quite a bit of positive pressure in the inlet system to lift the secondary valve of it's seat
Try it up the road under load
Old Mar 29, 2016 | 09:03 PM
Ellsa's Avatar
Ellsa
It's not quite finished yet so that will have to wait
Old Apr 1, 2016 | 03:22 PM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
As Tony says try it up the road when you can, but if it's a stock T3 then you should be able to get it to 'dump' or even chatter a little (EFI) from just revving it (Although just to point out if this is a fresh engine build you shouldn't be revving it at all!).
AiToR51
13
Dec 13, 2018 08:40 AM
zetaboostboy522bhp
Feb 12, 2017 10:00 AM
Brawlsteins
42
Mar 5, 2016 12:50 PM
madfortaryb
15
Mar 1, 2016 06:33 PM
mgtkr1
Feb 16, 2016 07:03 PM
