magnecor r100 and misfire
I own a sapphire RS Cosworth 4wd converted to 2wd. I had an issue with my magnecor ht leads R100
Firstly I had misfire when boost was higher than 1,3 bar at 5000rpm and upwards.
Later the same issue appeared when I simply raise boost higher than 0,2bar.
Finally I had misfire all the time except idle.
I believe that there must be something like a magnet field from magnecors and engine loom but I m not sure yet.
Has anybody ever had the same issue? Any solution?
I 've installed BERU Silicone and misfires stopped!!!!
I saw something else, I have installed an APEXi AVC-R, I ve allways had a problem with rpm readings when I've raised rpms higher than 5000 rpms, APEXi reading raised up to 9000 rpm when my real rev limiter is 7200rpm.
When I've changed my leads to BERU my APEXi AVC-R reading are ok, now I see 7210-7230
lee2cossies
Mar 6, 2016 04:54 PM
SmudgerByName
Mar 2, 2016 07:44 AM
