Hi, I have an ECU and a knock sensor engine... Is this compatible? Also I'm curious about the 'missing bolt' holes on the circuit board in the second image... Lemme know if it's good to use!
Also what is the little breather spout for? And does it need a hose on it to go anywhere?
Any help would be great, thanks!
Yes that ECU is compatible with the knock sensor, it is fitted with a superchip (as I'm sure you can see lol) and as Stu has said that's the MAP sensor hose fitting and should be connected to the inlet manifold directly.
