Help!!!! Can I use a mk3 oil pump on a mk4 escort turbo
Old Mar 23, 2016 | 03:13 PM
Unstablecable's Avatar
Unstablecable
Default Help!!!! Can I use a mk3 oil pump on a mk4 escort turbo
Please help me
Old Mar 23, 2016 | 04:36 PM
Fraggle...'s Avatar
Fraggle...
On a tangent
IIRC CVH have two different drive options off the crank..
There a two main pump types..Early upto 86 and after 86...
Also there is a higher pressure pump for turbo application.
Give Burton ... 020 851 891 36... a call fella, you will ideally need to find the engine number to be sure, or if pumps off they will know from your description.
Old Mar 23, 2016 | 04:58 PM
haz87's Avatar
haz87
Pre 86 crank needs pre 86 oil pump and vice versa for post 86.
They cannot be mixed and matched due to the crank nose being slightly different.
(basically as above)
Old Mar 23, 2016 | 07:22 PM
Unstablecable
Default Thanks for the help guys
I've got the old pump off. I can't seem to find another genuine ford pump for sale anywhere and have heard mixed reviews on burtons high pressure pump so was hoping to just replace with another genuine pump. The search continues. Thanks again for your help. 👍🏻👍🏻👍🏻
Old Apr 1, 2016 | 04:14 PM
Louis_RST's Avatar
Louis_RST
Are oil pumps no longer available at Ford?
Old Apr 2, 2016 | 06:58 PM
Unstablecable
Nah discontinued. Just Chinese shit gets made now
griffo69
Mar 28, 2016 05:42 PM
FORD RS MAD
Mar 16, 2016 08:39 PM
bluntys1rsturbo
Fiesta RS1800/RS Turbo
15
Feb 10, 2016 03:50 PM
original
Feb 4, 2016 04:00 PM
Mungus
Feb 2, 2016 09:27 AM
