Focus 2.0 16v help
Mar 10, 2016 | 10:37 AM
Focus 2.0 16v help
Hello,
I 'm french and I own an escort rs 1600i and focus 2.0 zetec .
I have a problem with the focus that I can not settle
When the engine is warm the regime to a lot of trouble down at times it remains squarely accelerated.
I have already changed :
slowed valve
vvs sensor
throttle position sensor
pCV valve
ford in there with no solution, no error message
Thanks for your help
sorry for the translator if the text is not very correct
Mar 10, 2016 | 10:39 AM
Mar 11, 2016 | 06:43 AM
Mar 11, 2016 | 09:28 AM
Quote:
Originally Posted by
kev 53
You might not be getting a response because this phrase doesn't make sense in English. Are you saying it has idle problems when warm?
Maybe check for vacuum leaks from a split hose or something?
Mar 11, 2016 | 10:37 AM
_Jimmy_
yes , the engine does not return to idle , he stays accelerate
Mar 11, 2016 | 12:38 PM
Air leak, or sticking idle speed control valve?
Mar 11, 2016 | 01:52 PM
air leak : not control
speed control valve : new
the water temperature sensor ? bad information to ecu ?
Mar 11, 2016 | 06:11 PM
Mass air flow sensor, they can upset the idle (engine revs, rpm).
Mar 11, 2016 | 06:19 PM
I try and engine malfunctions
Jul 18, 2016 | 08:25 PM
Oooooh bugger. Sorry, I somehow replied to the wrong thread.
steste9876
Oct 17, 2020 08:04 PM
salsheikh
Alloy wheels and ICE for sale
Feb 19, 2016 11:01 AM
salsheikh
Ford Focus ST Parts for Sale
Feb 16, 2016 10:49 AM
fordfocusmk1
Feb 14, 2016 06:31 PM
