Cosworth engine, needs assembly
205 block cosworth engine.
Block has been freshly bored and decked
Pocketed Mahles with new rings
Rods
CR all worked out to run standard
STD grind crank with new Mahle bearings (freshly polished)
4x4 head with 24.5/24.5 inlet and exhaust ports (freshly skin and guides checked etc)
2wd sump
Cams and pulleys
Complete 2wd inlet manifold with throttle body, reg, rail etc
The only things required are a few valves, pick up pipe
Will upload pictures tonight
£2000
Located in somerset
Rods
2wd sump
Cams and pulleys
£2000
Located in somerset
Tank Mike
Feb 2, 2016 10:10 PM
PAUL S
Jan 29, 2016 05:39 PM
