Compression struts fitting
Old Mar 8, 2016 | 09:31 PM
russ rs's Avatar
russ rs
Default Compression struts fitting
Hi
Has anyone got any measurements of where the base plate needs fitting on a mk4?
Take it got cut out the chassis rail?
And any photos if possible
Thanks
Old Mar 9, 2016 | 05:27 AM
gus's Avatar
gus
Mine go from the arb corner plates into the tca
Can't find a pic of it
Old Mar 9, 2016 | 11:54 AM
nigel b's Avatar
nigel b
if you are gonna use ones that go onto the chassis rails stu collins should have some pics,his was like that
Old Mar 9, 2016 | 12:49 PM
davidfox280585's Avatar
davidfox280585
mk2 escort kit would fit a escort and weld to chassis legs, considered this myself then use a mk2 arb with rose jointed drop links
Old Mar 9, 2016 | 04:39 PM
gus's Avatar
gus
Do front and back mounted jobbies work equally well?
Seems a no brainer if so. Mount from the front as it's the easiest option
Mine is and I have a arb all on rose jointed drop links for adjustment
Old Mar 9, 2016 | 05:35 PM
muz's Avatar
muz
Wye Valley Hardcore
Just out of interest, why do you want to use that sort of set up?
Old Mar 10, 2016 | 12:02 PM
nigel b's Avatar
nigel b
back mounted is usually better,think of the force on the tca when accelerating
what do a/r/bars work like
Old Mar 11, 2016 | 01:57 PM
russ rs's Avatar
russ rs
Going track antidote bar crap can't find 16i rollbar and car still on spit so works well on the mk1 so thought see how is and stu reckon his work fine.
Sam_RSi
Escort Range
Aug 1, 2016 07:13 PM
James Porter
Apr 29, 2016 01:27 PM
lockie
Mar 7, 2016 05:02 PM
kingflipper
Ford Fiesta
Mar 6, 2016 08:07 PM
kevin micallef
Mar 6, 2016 05:36 PM
