88 Escort Rs turbo zvh efi.....
Old Mar 8, 2016 | 03:21 PM
RSTurbo75's Avatar
RSTurbo75
Newcastle FC
Default 88 Escort Rs turbo zvh efi.....
Hi, i have a 88 Ford Escort Rst 2.1 zvh which ive owned for 4 years. I bought the car running on Mfi and decided to switch over to Efi... the car has been off the road now for 3 of the 4 years ive had it due to this efi conversion and down too not having alot of spare time to finish it off etc! Same old same old!! Now i'm at stage now were the car is more or less all done meaning all the efi gear is fitted and the car is turning over but i'm NOT getting no spark! Ive checked more or less everything over and no joys! Ive got a Fiesta Efi Rst flywheel fitted....My car also has an st170 bottom end so i have the zetec 2.0L cps housing that kicks the sensor off at a slight angel for the pick up, my cps sensor also is from 2.0L zetec and is brand new. Ive also tried the bracket setup on the bottom crank to see if that would do the trick but again no joys. The only thing left to try is the eddis module and swap that over for a new one to see if that is the problem. Right what i'm getting here i'm based in Grimsby, Lincolnshire and i am looking for a Good well known Specialist local as possible to me who i can take my car too and go through it and basically get the car all done and sorted, i have a brand new made up braided wiring loom fitted for the efi setup replicated from a Fiesta Rst, so there is my old mfi loom that needs to come out which i want sombody that can do the lot and get the car back to me done.
Any help will be much appreciated.
Thanks
Ryan
Old Mar 15, 2016 | 02:23 PM
Ettles1986's Avatar
Ettles1986
Any chance in some advise I need some advice what ecu do I use the ofab? How do u get the right fuel ? Thanks
anthony lea
Oct 7, 2016 05:24 PM
anthony lea
Oct 7, 2016 05:23 PM
ads rst
Jan 7, 2016 03:36 PM
anthony lea
Jan 7, 2016 09:59 AM
Ellsa
Jan 5, 2016 02:17 PM
