Time for a engine change?
Old Mar 7, 2016 | 04:03 PM
povey@pembrokeshire's Avatar
povey@pembrokeshire
Default Time for a engine change?
After towing a friend twice in his van my little escort 1.6 zetec has lost some power not sure what has happened clutch is good
Old Mar 7, 2016 | 04:05 PM
haz87's Avatar
haz87
Towing puts a bit of extra strain on the engine/chassis but shouldnt just lose you power.
Checked all the basics? Plugs/HT leads etc etc.
Shock of pulling a vehicle hasnt caused any wiring/connectors to come away from their sensors etc?
In what way does it feel likes its "lost power"? 2.0 conversion is a huuuuuge improvement over the 1.6
Old Mar 7, 2016 | 04:32 PM
Fil's Avatar
Fil
ELASTIC BAND
I think an LS1 engine is the only real solution to your issues
Old Mar 7, 2016 | 05:12 PM
povey@pembrokeshire
I have lost power on acceleration put my foot down takes a lot longer to respond than it used to
My friend suggested putting a 1.6 cvh block in it with the zetec head?
Old Mar 7, 2016 | 05:14 PM
povey@pembrokeshire
No thanks would rather put a diesel in it
Old Mar 7, 2016 | 05:19 PM
gjh's Avatar
gjh
The other way round works, zetec block, CVH head, to give you a ZVH hybrid.
Old Mar 7, 2016 | 05:25 PM
Fil's Avatar
Fil
ELASTIC BAND
well that would have a decent amount of torque fit towing!
Old Mar 7, 2016 | 05:45 PM
povey@pembrokeshire
How hard is it to do or is it easier to put a 1.8 in it
Old Mar 7, 2016 | 05:48 PM
povey@pembrokeshire
Don't think I'm going to do much towing I had it moted and the guy recommend cutting the tow eye off because I almost ripped it off anyway
Old Mar 8, 2016 | 05:27 PM
gjh's Avatar
gjh
Just search ZVH engine on here in the search bar above and there will be plenty of stuff to help you out.
J690Turbo
Ford Escort RS Cosworth
17
Jun 8, 2024 12:46 PM
Rs(555)
Feb 28, 2016 08:31 PM
bassboy
Feb 26, 2016 03:09 PM
Robliddle
Feb 16, 2016 06:32 PM
Stitches
Feb 9, 2016 08:29 PM
