Oil Pressure question on a YB Cosworth
I'm trying to find the correct oil pressure on a YB Cosworth engine with a HP Oil pump.
I've installed an innovate gauge and I saw the following readings:
Engine Cold: 5,55bar (about 80psi)
Engine's optimum temperature (4wd 82C)
idle(aprox 1000rpm): 2,2 to 2,6 bar (32-38psi)
2000rpm: 4 bar (58psi)
3000+ rpm: 4,5-5 bar (65-72psi)
Engine oil: Motul V300 10/40
Ambient Temperature 15+C
Is it OK?
Anyone else with readings on a HighPressure oil pump on a YB Cosworth???
Thank you!!!!
Is it OK?
Thank you!!!!
I have the 4wd thermostat 82C its from MSD
Gauge temp seems that it works ok!
I do not see low temps on my cooling system.
You think that for High Pressure Oil pump readings are OK???
There is nothing wrong with running the cooler temp thermostat, as the cossy engines will get hot. The oil pressure readings also seem fine. Nothing to worry about in my opinion.
Tommy777
Feb 10, 2016 09:46 PM
Romain 83
Feb 10, 2016 09:26 AM
Yummi
Ford Mondeo Including ST
Feb 6, 2016 05:53 PM
