Vacuum feed for brake servo
Well obviously you will be using a dedicated takeoff for the servo and of adequate size for the servo.
it would be foolish to take a servo of the same line as a map sensor etc.
I just use a non return valve like this 10-12mm will be fine, I would not use smaller pipework for a servo.
http://www.ebay.co.uk/itm/Chrome-Fue...i-TuGFJgBM0OBw
jdsjojo
84
Mar 25, 2016 04:25 PM
