Cosworth subframe bolt sizes
Old Mar 1, 2016 | 06:21 PM
Adam-M's Avatar
Adam-M
Default Cosworth subframe bolt sizes
This may be a long long shot but where I'm working just now there's an iron mongers that sells a big range of different sized bolts inc high tensile ect and I wondered while I've got the front subframe stripped off my 2wd saff I wouldn't mind replacing all the bolts I removed. I know MT Motorsport does a kit for this but they won't arrive by time I'm home.
I was wondering if anyone could provide bolt sizes for the following...
4x bolts that hold the subframe onto the chassis legs, sure they are M12
2x bolts that hold the steering rack onto the subframe
4x bolts that hold the arb brackets to the floorpan
2x inner TCA bolts.
Track rod end nyloc nut size iirc it's m10
Tried searching on google for this info but can't find it and I won't be back home to measure the bolts I removed until Friday.
Thanks Adam
Old Mar 3, 2016 | 04:15 PM
cossynut2's Avatar
cossynut2
10 Year Member
2x inner TCA bolts.
Thanks Adam
There was a thread on here a few weeks back about the bloke who bought a job lot of every nut,bolt ,screws and clips etc for every Ford model made. I am sure he will have the correct brand new Foed ones you are after.
Old Mar 3, 2016 | 09:35 PM
Ridgey's Avatar
Ridgey
Track rod end nuts are fine fine m10 from memory, not easy to get.
155lee
Feb 25, 2016 09:02 PM
Alvyn
Wheels and Tyres
Feb 23, 2016 01:17 PM
dingla rs
Feb 11, 2016 10:01 AM
James Porter
14
Feb 11, 2016 02:09 AM
mk2cossy
Feb 7, 2016 10:10 PM
