compression ratio
Old Mar 1, 2016 | 12:36 AM
jimhc's Avatar
jimhc
big jc
Default compression ratio
I'm looking what CR should be for 400 - 450bhp. Standard 4x4 pistons .25 or bore valve cut outs. Bd10 exhaust and bd14 inlet
Old Mar 1, 2016 | 09:24 PM
Adam-M's Avatar
Adam-M
Are you asking what CR people recommend or what CR your engine is right now?
Old Mar 2, 2016 | 12:01 AM
jimhc's Avatar
jimhc
big jc
What it should be
Old Mar 7, 2016 | 08:48 PM
Bart's Avatar
Bart
What head you have?
Old Mar 9, 2016 | 09:50 AM
jimhc's Avatar
jimhc
big jc
2wd head
Old Mar 16, 2016 | 05:52 PM
Bart's Avatar
Bart
Around 7.8 if not skimmed to much
Old Mar 18, 2016 | 10:42 PM
cossynut2's Avatar
cossynut2
10 Year Member
I am not sure if there is an exact science to work it out but 7.4 to 7.8 seems to be what most big power engines have. Are you building the engine yourself or having it done by a Cosworth specialist?
Old Mar 19, 2016 | 10:02 AM
MK MOTORSPORT's Avatar
MK MOTORSPORT
i think that is well to low ,at least standard now seems to be the way forward
Old Mar 19, 2016 | 11:09 AM
cossynut2's Avatar
cossynut2
10 Year Member
Maybe things have changed but most big power Cosworth YB turbo engines have low comp. High comp used to be more for N/a engines. What reason is there for having the higher comp ratio?
Old Mar 19, 2016 | 11:17 AM
JamesH's Avatar
JamesH
You need to speak to Mark Shead
Old Mar 19, 2016 | 01:31 PM
MK MOTORSPORT
i think low comp was a long time ago,high comp less lag better off boost driving etc just a nicer car all round as james says mark shead has been running higher comp for a while and from what people say his engines seem to be the best now
Old Mar 20, 2016 | 09:07 PM
Bart's Avatar
Bart
I would go 9/1 with good ecu.
Old Mar 20, 2016 | 10:55 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Maybe 10 years ago but mines at 8.6 : 1 & is the modern way.
big_wasa
12
Sep 6, 2016 08:56 PM
Marc D
Mar 2, 2016 08:14 AM
Ford Focus ST Parts for Sale
Mar 1, 2016 07:03 PM
smithy rs2k
Feb 23, 2016 03:55 PM
Rsturbo519
Feb 22, 2016 07:23 AM
