Best Actuator on standars S2 engine.
Hi guys.
What is the best actuator to use on a standard S2 engine?
The specs:
Engine is rebuild to original spec. New original Garret turbocharger.
Larger intercooler, K&N panel filter and 2.5" stainless mongoose exhaust.
Hart/diamond/hash ECU, original, not chipped.
I used an old original actuator on the new turbo charger, but it seems the actuator is a bit tired. Starts to open at 0.2 bar (2.9psi)
I only find -18 or -31 actuators beeing sold. But what do these numbers mean? Which should I choose?
Thanks,
The specs:
Thanks,
You sometimes can struggle on a -31 as depending on how well the map sensor works in the ECU they can boost cut at 9psi without a chip in them, and the -31 has a 9lb spring, so you have to run next to no preload.
I've had to chip them before just to prevent them clipping the boost cut.
ossie cossie
13
Feb 21, 2016 06:29 PM
rb5286
Feb 2, 2016 11:38 PM
Bigdaggy123
Ford Focus (All Models)
Feb 1, 2016 03:41 PM
