cosworth parts
Old Feb 28, 2016 | 08:13 PM
cos elle's Avatar
cos elle
Default cosworth parts
Cosworth parts for sale all are plus post or collect and will add pictures when asked
4x grey injectors in vgc £170 SOLD
garrett t38 .63 exhaust housing has back and forward play and little side to side play £300 SOLD
escort cosworth under carpet polystrene mould £50
escort cosworth boot floor carpet £100
escort cosworth pas metal pipe £30
escort cosworth plastic header tank £25
escort cosworth front fog switche £5
escort cosworth rear arb clamps £15
escort cosworth abs pump £50 SOLD
escort cosworth driver side wheel arch boot carpet £25
escort cosworth a pillar gauge pod with two hole for led lights £15 SOLD
escort cosworth cosworth A pillar covers L/R £25 SOLD
escort cosworth cosworth sill trims 3 x drivers side 1 x passenger side £15 each
escort cosworth fuel tank £100
escort cosworth BT intercooler £50
escort cosworth front ARB x2 £30 each
escort cosworth pedal box £30
escort cosworth door windows L/R £20 collect only or sort own courier
escort cosworth metal fuel plpes feed and return from under the car £50 collect only or sort own courier
escort cosworth inside plastic boot trim £15
escort cosworth oil pick up plpe £20 SOLD
escort cosworth rear diff mount vgc £25
escort cosworth bonnet catch £10
escort cosworth forge motorsport oil breather £100 SOLD
escort cosworth forge motorsport cooling swirl pot £60 SOLD
escort cosworth fuel regulator bosch as new put in but not run £40
escort cosworth fuel regulator used £25
escort cosworth steering column UJ £25
cosworth 2wd fuel rail £20
cosworth intercooler to throttle body graham goode racing hose in blue £20
sapphire cosworth front grill no mesh £20 SOLD
cosworth 2wd forge motorsport header tank £120
cosworth 2wd power steering cooling metal pipe £25 SOLD
cosworth 2wd steering column UJ x2 both need new bushs £20 each
cosworth 2wd gearbox cradle £50
cosworth 2wd rear ARB £15
cosworth 4x4 engine cradle £30
cosworth turbo oil return pipe £10
cosworth powerflex yellow front top shock bushers like new £25
sapphire cosworth moonstone blue doors in gc £20 each
cosworth 2wd engine cradle £20
cosworth 2wd front ARB £25
cosworth sapphire head lights vgc £40 each in vgc
Old Mar 4, 2016 | 06:14 PM
AndyPen's Avatar
AndyPen
2wd engine cradle and power steering cooling pipe posted mate?
Old Mar 5, 2016 | 08:04 AM
big mac's Avatar
big mac
Default T38
escort cosworth fuel tank £50
escort cosworth pedal box £20
cosworth 2wd gearbox cradle £15
You have PM regards turbo bud
Old Mar 5, 2016 | 08:12 AM
155lee's Avatar
155lee
Pm sent
Old Mar 5, 2016 | 06:28 PM
cos elle's Avatar
cos elle
pm sent cheers
Old Mar 5, 2016 | 07:29 PM
VEEDUBBED's Avatar
VEEDUBBED
Any chance of getting a photo of the BT escort intercooler?
Cheers.
Old Mar 6, 2016 | 09:13 PM
RSCossieGaz's Avatar
RSCossieGaz
You still got the powerflex yellow strut top mounts? If so how much delivered pls
Old Mar 7, 2016 | 12:41 PM
cos elle's Avatar
cos elle
£30 mate
Old Mar 7, 2016 | 12:42 PM
cos elle's Avatar
cos elle
Default pics
will put pictures up tomorrow of what people have asked for cheers
Old Mar 8, 2016 | 10:09 PM
ekjim's Avatar
ekjim
Is the turbo roller bearing , pics please .
Old Mar 8, 2016 | 10:31 PM
AndyPen's Avatar
AndyPen
pm sent cheers
Just picked it up sorry - replying now
Old Mar 12, 2016 | 08:19 AM
byrrul's Avatar
byrrul
I'm still after a 4x4 crossmember, is it or the MK Motorsport modified one still available?
Old Mar 12, 2016 | 07:46 PM
cossie09's Avatar
cossie09
Hi pictures or the power steering tank.
Old Apr 10, 2016 | 08:34 PM
marco polo's Avatar
marco polo
Hi can I have the 2wd fuel rail with standard regulator please
Cheers Marco
Old Apr 10, 2016 | 09:41 PM
clipper49's Avatar
clipper49
Have you still got the A pillar covers?
Old Apr 10, 2016 | 09:49 PM
555's Avatar
555
I am after;
N/S rear door
Roof lining?
Regards
Josh
Old Apr 10, 2016 | 10:07 PM
Cosnada's Avatar
Cosnada
Is this big or small turbo?
If small I will have it 😀
Old May 15, 2017 | 07:36 AM
mark r's Avatar
mark r
Hi mate , have you any front suspension uprights 4x4
cheers mark
Old May 15, 2017 | 09:01 AM
cos elle's Avatar
cos elle
cheers mark
No sorry
Old May 20, 2017 | 05:47 AM
curt randerson's Avatar
curt randerson
hi there is the boot plastic trim the one that goes on the tailgate or the one for the body? cheers
Old May 20, 2017 | 08:39 AM
cos elle's Avatar
cos elle
Hi yeah it fits to the escort boot
Old Dec 12, 2017 | 06:00 PM
jens henrik vinther's Avatar
jens henrik vinther
Hi. Do you still have the fueltank is the fuel sender still in it??
Old Dec 30, 2017 | 02:28 AM
oohogwash1's Avatar
oohogwash1
hi is the bonnet catch both sides still there ?
Old Dec 30, 2017 | 09:03 AM
Adam-M's Avatar
Adam-M
Interested in the turbo oil return pipe, is it off a 4x4?
Old Dec 31, 2017 | 12:48 AM
oohogwash1's Avatar
oohogwash1
Do you have both parts of the bonnet latch please ? and maybe the cable ?
Old Jan 2, 2018 | 07:43 PM
ricky's Avatar
ricky
Have you got the steering rack bolts
Old Jan 6, 2018 | 07:12 PM
oohogwash1's Avatar
oohogwash1
Also can i get the id plate, mine has now been stolen :-(
Old Jan 14, 2018 | 11:49 AM
cos elle's Avatar
cos elle
Hi i have a escos fuel tank no sender cheers
Old Jan 14, 2018 | 11:50 AM
cos elle's Avatar
cos elle
Hi bonnet catch for what car cheers
Old Jan 14, 2018 | 11:51 AM
cos elle's Avatar
cos elle
Hi i have a vgc 2wd turbo oil return pipe
cos elle's Avatar
cos elle
No sorry
Old Jan 14, 2018 | 05:18 PM
Adam-M's Avatar
Adam-M
Need a 4x4 one mate due to the manifold I’m running
Old Jan 21, 2018 | 11:05 PM
JPA's Avatar
JPA
Do you still have some Escort bits left as per your list ?
John
Old Jan 31, 2018 | 05:18 PM
ricky's Avatar
ricky
You got the steering rack to cross member bolts
massivewangers
Feb 8, 2016 01:51 PM
MADMAXPTT
Jan 6, 2016 06:09 PM
VEEDUBBED
Jan 5, 2016 02:40 PM
Jack and the Beanstalk
Jan 5, 2016 05:27 AM
ekjim
65
Jan 4, 2016 05:23 PM
