coilover helper springs
Old Feb 27, 2016 | 02:45 PM
siscossie's Avatar
siscossie
3-door moonstone
Default coilover helper springs
Has anyone got these on there cossie just putting mine back together and thinking of getting some for the rear, just wondered what size and poundage people are using
Old Feb 27, 2016 | 07:19 PM
Ade's Avatar
Ade
Fast Ford snapper
Just get really soft ones. That's what I did. All they are for it to stop the spring dislocating after all.
Old Feb 27, 2016 | 08:19 PM
jonfoc's Avatar
jonfoc
It's best to get ones that compliment the spring rate already used. They are there to stop dislocation but if they are too soft they won't react fast enough to fill the void. Match them correctly is the best option, that way they will fill the void when needed and "help" the main spring. Dual rate springs in effect.
Old Feb 27, 2016 | 10:06 PM
Ridgey's Avatar
Ridgey
Go to coilover supplier and get helper springs, no need for poundage, as when car is on its wheels it is full compressed.
Old Feb 28, 2016 | 05:32 AM
jonfoc's Avatar
jonfoc
I work at Leda suspension and trust me there is a need for the correct poundage or they do not work correctly. Not arguing just telling you fact! Otherwise they would all be the same rate and thickness.
Whatever you choose to do make sure you reset your geometry. A 20lb 50mm helper will fully compress to about 13mm a 100mm 70 lb will be about 45mm or more from memory.
Old Feb 29, 2016 | 11:07 AM
Ridgey's Avatar
Ridgey
Is there a difference between Helper and Assister springs?
Old Feb 29, 2016 | 12:52 PM
jonfoc's Avatar
jonfoc
Depends in what context we are talking. Basically helpers help fill the droop gap and assister springs help the main rate spring. The problem with fitting the softest helpers is that a main rate spring has a mass. If the helper is too weak it cannot react fast enough to fill the droop void, so dislocation still occurs. Too heavy and it won't compress. Best thing to do is measure the droop gap then return damper to manufacturer and have an internal droop stop fitted
Old Feb 29, 2016 | 05:02 PM
siscossie's Avatar
siscossie
3-door moonstone
Will measure up and take it from there cheers for the help felas
Old Feb 29, 2016 | 06:32 PM
Ridgey's Avatar
Ridgey
Thought so.
Meekoblue
May 6, 2016 04:06 AM
Mark V8
16
Feb 25, 2016 04:04 PM
fatboy billy
Feb 23, 2016 08:30 PM
modifyitmike
Feb 22, 2016 08:26 PM
