Air to air
Old Apr 7, 2005 | 07:26 AM
killerscum01's Avatar
killerscum01
Default Air to air
Hi everyone,
Can anybody tell me which injectors are used on an air to air injection system? And also where it plumbs to?
Is it where the amal valve plumbs but without the pipe to the air filter.
Any help would be appreciated as i am going to fabricate one myself.
Thanks in advance.
Old Apr 7, 2005 | 07:34 PM
Niall.b's Avatar
Niall.b
Yes, the air injectors replace the amal valve & use its wiring. check your ecu as it will need modded or changed to run them depending on model
Old Apr 8, 2005 | 07:26 AM
killerscum01
Cheers Niall.
I have an S8 ECU from secs.
Do you know what injectors are used or are they specific to air to air systems?
Thanks: Berkeley
Brickhouse
14
Oct 3, 2015 07:28 PM
fordrallycar
Sep 30, 2015 07:57 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
