Lost indicators but work when hazard switch is pressed
Old Feb 25, 2016 | 02:28 PM
bassboy's Avatar
bassboy
Default Lost indicators but work when hazard switch is pressed
Hi everyone, I seem to have lost the indicators which were working perfectly fine before I removed the dash...
I have checked the earth lead on the loom and its definitely earthed out
Now that things are going back in, I tried the indicators and they dont work, tried hazards and they dont work...when the alarm is switched on/off, the lights flash as per normal. If I press the hazards, nothing happens, but if the hazard switch is pressed and I try to indicate, they work fine...
I tried a new relay on the stalk and it made no difference
I also tried another indicator stalk and thats also doing the same time....
Can anyone help?
Old Feb 26, 2016 | 03:09 PM
bassboy's Avatar
bassboy
Solved
iantwj27
Ford Focus Diesel
Feb 26, 2016 02:42 AM
mark m
11
Feb 25, 2016 07:14 AM
3doorcozmess
Feb 22, 2016 08:10 PM
cossynut2
Feb 19, 2016 05:55 PM
