Front bumper mods/opinions.
Old Feb 20, 2016 | 10:15 AM
muz's Avatar
muz
Wye Valley Hardcore
Default Front bumper mods/opinions.
I've been having a think what to do with my front bumper to make it a bit different.
It looked this this to start
So I've taken it and cut more out the centra bar and straightened up the cuts which didn't need enlarging, enlarged the brake cooling ducts on the front, blended the tow eye cover and put mounts on the attach an Laguna splitter on the bottom.
However, I've been thinking about putting some NACA ducts in the sides, like these.
This is the size they would be and they would be blended in, rather than riveted on.
They would be functional feeding the oil cooler, brakes, and when I fit it the gearbox cooler, but I'm also aware of the fact you can "overdo" things. I don't want the car too look like I'm trying too hard, if you get me.
What's people thoughts on this?
Old Feb 20, 2016 | 02:28 PM
russ rs's Avatar
russ rs
Yes
Old Feb 20, 2016 | 03:10 PM
boeb's Avatar
boeb
Think that would work m8..deffo blended in but not riveted
Old Feb 20, 2016 | 05:16 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
what would you use to blend them in that wouldn't crack on a plastic bumper? I remember having endless trouble trying to blend into a bonnet and no matter what I used it always cracked with the bonnet flexing.
Old Feb 20, 2016 | 05:21 PM
muz's Avatar
muz
Wye Valley Hardcore
I was going to PU seal them on from the rear then fibreglass them into shape and light skim of filler. I didn't give any consideration to them cracking to be honest, although that could be a problem...
Old Feb 20, 2016 | 07:04 PM
studabear's Avatar
studabear
Slightly off topic, but that bonnet is awesome.
Old Feb 20, 2016 | 07:43 PM
muz's Avatar
muz
Wye Valley Hardcore
I'm trying really hard to be modest, but yes, yes it is lol
Old Feb 20, 2016 | 08:07 PM
Where you have cut the bumper for the intercooler i would finish the edges and make some returns like i have on mine
Old Feb 20, 2016 | 08:33 PM
muz's Avatar
muz
Wye Valley Hardcore
By returns you mean like the 'walls' either side of the cooler?
Old Feb 20, 2016 | 08:53 PM
Yes mate
Old Feb 20, 2016 | 08:57 PM
muz's Avatar
muz
Wye Valley Hardcore
I probably should, but as my cooler sits so far forward it's not too bad without them. I might look into it though. Shame the car's 250 miles away so I can't do a test fit!
Old Feb 21, 2016 | 03:03 AM
visa_broke's Avatar
visa_broke
10 Year Member
both your car and twin's car are epic and make me miss my xr3i and rs turbo loads.
Off topic muz whats the extra bonnet vent off?
Old Feb 21, 2016 | 06:52 AM
Hobomassiv's Avatar
Hobomassiv
I recall Lancia but i could just be totally making that up.
Old Feb 21, 2016 | 07:13 AM
jonfoc's Avatar
jonfoc
Those ducts look great Muz. I'd be leaving them bonded though or riveted. The rest of the car looks Motorsport so I reckon they would suit it.
Old Feb 21, 2016 | 11:04 AM
muz's Avatar
muz
Wye Valley Hardcore
both your car and twin's car are epic and make me miss my xr3i and rs turbo loads. Off topic muz whats the extra bonnet vent off?
80% of the bonnet is Lancia Delta. I was just going to use the vents but decided to graft the whole thing into an Escort frame inc the power bulge.
Old Feb 21, 2016 | 11:06 AM
muz's Avatar
muz
Wye Valley Hardcore
I'm probably going to have to rivet them on as I'm wary about smoothing them now. The bumpers just a shell now so not very strong and does flex a lot. Someone Unknown moved it yesterday as I'm doing it at work and obviously picked it up using the lower bar and cracked all the filler around where I smoothed the tow eye so had to dig it out and re do it.
Old Feb 21, 2016 | 11:15 AM
vinnyvangough's Avatar
vinnyvangough
Are the NACA Ducts plastic? Could you plastic weld them on?
Old Feb 21, 2016 | 11:28 AM
muz's Avatar
muz
Wye Valley Hardcore
Yeah, the ones is use are plastic. Could plastic weld them but could still crack where they are skimmed. I'll probably go with them riveted on.
Old Feb 22, 2016 | 01:33 PM
gus's Avatar
gus
Gonna look cool I think dude
I'm like your way of thinking
Will you be able to duct to brakes on lock?
Old Feb 22, 2016 | 01:59 PM
muz's Avatar
muz
Wye Valley Hardcore
What do you mean?
I'm thinking about making some shrouds in time which bolt onto the hub. With the size of the brakes it probably doesn't need it, but I like the idea of just developing the car further when it's "finished"
Old Feb 22, 2016 | 02:07 PM
muz's Avatar
muz
Wye Valley Hardcore
Ah, you you mean, will the ducting work with the steering moving from lock to lock?... We'll see.
Old Feb 22, 2016 | 02:17 PM
StephenC's Avatar
StephenC
..BS Motorsport..
Would the vertical vents from mk1 frs go in? Just another thought
Old Feb 22, 2016 | 02:38 PM
gus's Avatar
gus
Yeah that's it
Be interesting mod for sure
Old Feb 22, 2016 | 02:48 PM
muz's Avatar
muz
Wye Valley Hardcore
They look cool, but seem like a bit of a gimmick to me. They can't be up to much cooling wise, unless they were turned around to force air in.
What I'm thinking is 2 1/2 inch aluminium tube which runs along the bottom of the chassis here
Redesigning the calipers brackets to allow a shroud through this hole in the hub between the calipers mounting tabs, maybe.
Connected with flexi tube at both ends then into some sort of hub mounted shroud like this,
Old Feb 22, 2016 | 03:48 PM
gus's Avatar
gus
They look cool
Old Feb 22, 2016 | 08:27 PM
vinnyvangough
If you had them welded in and had the plastic weld raised, you could then sand/grind the plastic back to flush with no risk of cracking. It would be as if it was one bit of plastic.
We have been repairing some of our bike fairings and used this technique to avoid the use of any filler thus eliminating the risk of cracking.
Bazars
27
Jul 17, 2016 12:56 PM
paceo
Feb 8, 2016 08:02 PM
RickoG66
16
Feb 5, 2016 02:26 PM
COLEYST200
Jan 29, 2016 11:10 AM
Bazars
Jan 26, 2016 08:14 PM
