Focus ST MK2 - RS clutch difference
Old Feb 15, 2016 | 05:32 PM
slippytoe's Avatar
slippytoe
Default Focus ST MK2 - RS clutch difference
Evening all,
My 2007 Focus ST MK2 is currently having an RS clutch installed that I bought on eBay... My mechanic tells me that the clutch is identical, to the point that the part numbers on the casing are the same. I am just wondering if the ST and RS clutch/ flywheels look identical. It wouldn't surprise me if the housing for it all is the same and uses the same part numbers and the friction plates etc are higher rated? Just wondering if anyone has any experience/ advice....
FYI I'm having the RS clutch put in because dreamscience remap is causing the standard clutch to slip...
Thanks!
Old Feb 15, 2016 | 05:34 PM
chris cdti's Avatar
chris cdti
Only the pressure plate is different, the clutch disc is the same.
Old Feb 15, 2016 | 05:39 PM
slippytoe's Avatar
slippytoe
Thanks Chris, understandably feeling a little worried!
Sp3no
Feb 22, 2016 12:34 PM
(BLACK DRAGON)
Feb 19, 2016 12:20 PM
2Litre
Feb 14, 2016 11:21 AM
morg65
Escort Range
Feb 11, 2016 10:04 AM
ossie cossie
Escort MK 5 / MK 6
Feb 11, 2016 08:22 AM
