Zetec Decomp plate
Not sure what option to use, lots of people say they have got good results with decomp plates but there is not much info on best way to actually fit them.
I was also looking at some low comp Accralite pistons from Burton Power but have read some old posts saying they are rubbish.
It really depends on the power you want but if cash isn't the issue go with pistons and rods and do it once every time.
Ona budget, If your happy with 220~250 just drop the cr a tiny bit. If your happy with 300bhp ish go with the st bottom end. If you want more it's got to be done with pistons and rods.
Whats the crack with the Vauxhall c20let pistons. Having read lots of info on the zetec turbo subject, altering the Vauxhall pistons to fit the zetec rods seems to crop up lots but a set of these pistons dose not seem that much cheaper than ones actually designed for the zetec , unless I'm looking in the wrong place. By the time you have factored in a re-bore and pin alteration as far as I can see there is not much difference in price.
(BLACK DRAGON)
Feb 19, 2016 12:20 PM
