3dr abs sensor removal
Old Feb 10, 2016 | 06:06 PM
siscossie's Avatar
siscossie
3-door moonstone
Default 3dr abs sensor removal
Is there a way of getting the front abs sensors out on the 3dr with knocking them?
Old Feb 10, 2016 | 09:58 PM
martysmartie's Avatar
martysmartie
They do become stuck.
The trouble is if you are too rough, you will end up snapping it off and replacements are hard to come by and expensive!
Martin
Old Feb 11, 2016 | 02:07 PM
siscossie's Avatar
siscossie
3-door moonstone
Been soaking it for a few days to loosen it a bit hopefully it will move
Old Feb 11, 2016 | 03:13 PM
costina's Avatar
costina
Live long and prosper!!
Si they are a bitch as Martin as said.
but once you get them to rotate they normally come out.
Old Feb 11, 2016 | 05:38 PM
Vincereese's Avatar
Vincereese
Default Abs
Snapped mine getting off other day , it would not come out. So I'm after some if anybody has one ,,,,,
Old Feb 11, 2016 | 09:11 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Rotating them does help, but the issues are that the rubber o-ring stops being rubber and that hold them in situ
I found that turning then first so that there was the possibility to get a small screwdriver underneath the lip, then squirting some WD40 into the gap normally did the truck
Don't forget that too much lube inside will ruin the grade for the bearings
Old Feb 12, 2016 | 06:56 PM
siscossie's Avatar
siscossie
3-door moonstone
Got them spinning all the way round but the little buggers won't come out
Dare not swing on them any more as there only plastic
James Porter
Feb 11, 2016 10:33 AM
vahurix
Feb 7, 2016 09:21 AM
mrbox
Feb 4, 2016 03:55 PM
TheBottleCracker
Jan 13, 2016 01:09 PM
R4N SS
Jan 12, 2016 09:53 AM
