Looking for these raw plugs guys- pretty urgent :-)
I think they call them a plastic rivet. The ford ones are round rather than oval though.
Also i think its rawlplug, not raw if that helps.
anything that matches on this page? Should help pin down which manufacturer they are from. http://www.clipsandfasteners.com/Gro...crew_s/104.htm
I'd give them a call, they can probably tell you or at least say which oem part number they correspond to and then you could find out the size from that part number.
392B.H.P.SAFF
24
Jan 24, 2016 09:25 PM
