Which Chip fin my L8
Hi,
I am having some trouble with my 92- 4x4, which I purchased a while ago..I do not know the history of the car, nor what has been done to it....I started with opening the ECU, to see what Chip that were installed.....There is a label on it, with the text: 3BL8CAT.803. I suspect it to be some kind of "Green" setup, based on the text, but would really appreciaete any assistance to verify were it comes from.....Other modifications to the car is light blue injectors, GpA fuel pump, KRX400Turbo, 3" exhaust, MSD ignition system....
Hi,
The car has run for several years with this Chip, prior to I purchased it, I am not afraid of the engine. I just wonder if anyone, knows were this Chip came from, and what it was intended for ?
