main and big end bearings.
Hi Gents
Need to source main and big ends bearing all at standard size.
What are people using. I've been told to use cosworth brand only but looking on burtons they don't have standard size.
Cheers Si
Cheers Si
vandervell are now part of mahle, i'm not sure that they make cossie bearings any longer? ACL are also out of the picture in std size usually, as they went bust last year and everyone is running out of stock.
King have entered the 'race bearing' market these days, i imagine they would be fine as i've never really heard of problems with their bearings. your other choice would be Glyco, but i'm not 100% sure that they make lead-copper cossie bearings now? certainly worth a look though.
My builder is old school and wants me to use cosworth brand. I was thinking acl
Mahle are relocatating their factory and are no making bearings so I am told for several months
ACL closed down in 2012/2013 now back up and running.
King are now available in a lead copper race specification, some engine builders do not like them, but you are not spoilt for choice.
Steve
I got Mahle Motorsport in std size from Burtons for mine
http://www.burtonpower.com/mahle-mot...m1002-std.html
http://www.burtonpower.com/mahle-mot...c1001-std.html
I've used King in a few non Cossie engines, not a damn thing wrong with them. They're very good quality
I'd never even heard of them til a few years ago Dave Baker ( Pumaracing ) on Pistonheads mentioned them, he's used them for years. And if anyone knows his posts and knowledge, he'd be one fussy bastard.
ACL and all the others, cant really fault them either.
all of the bearings mentioned above would be fine imo
if an engine spins a bearing or whatever , 99% of the time its something else that's caused the bearing to fail, lack of oil, pump failure etc
Cosworth branded bearings were made by Vandvell which is now part of Mahle.
Steve
Steve
Engine Parts UK seem to be listed as main importers for both King and ACL
If it's same place I emailed a few years ago about King bearings for my LS...the prices they quoted me were insane.
I got them for a fraction of the price from the US...and the US had them in stock.
http://www.enginepartsuk.net/
Local place Powermax can usually get either of them too and I know they work at some Cossies, give them a call.
http://www.powermaxengineering.com/
The Mahle Motorsport ones are a joke over 200 quid
And were you using ACL or ACL Race series bearings ?
The UK importer switched to King as an alternative as ACL had been in administration for nearly two years hilst they were looking for a buyer, then they ceased trading/production, then eventually restarted.
The UK imported sorted out most of the European stock, which bearings were needed for what engines.
Many companies have ACL listed but do not have any stock or have old stock.
Male Motorsport are available for the YB in most sizes including standard, they have always been more money.
You should not be moaning about paying an extra £80-£100 for better specification bearings for an engine build which will cost several thousands of pounds.
I have had communication back from Mahle explaining that their Motor Sport range of bearings is available and production of their general grange of bearing should be back in production within the next two months.
Steve
zetaboostboy522bhp
Feb 12, 2017 10:00 AM
cossie09
42
Mar 14, 2016 04:39 PM
siscossie
Jan 31, 2016 12:24 PM
