s1 rs turbo fuel pump
Old Feb 2, 2016 | 08:44 PM
kyam786's Avatar
kyam786
S1 RST LUV
Default s1 rs turbo fuel pump
I bought my first s1 when I went to view it I started it and it turned over the first time and left a deposit I went to pick it up today and it would'nt start the fuel pump isn't coming on I put the pump relay onto another s1 and it seems to be working I directed the pump and the pump is fine what could be the problem can anyone please help
Old Feb 2, 2016 | 08:59 PM
studabear's Avatar
studabear
Wiring or immobiliser fault from the sound of it.
Old Feb 3, 2016 | 07:26 PM
Chas's Avatar
Chas
What happens if you bridge/short out the main fuel pump wires in the relay plug?
Old Feb 5, 2016 | 11:53 PM
kyam786's Avatar
kyam786
S1 RST LUV
Default Mfi to efi
I've been advised to go efi and it wouldn't give me problems what do you reckon should I take his advice and go efi
Old Feb 6, 2016 | 12:00 AM
kyam786's Avatar
kyam786
S1 RST LUV
Default Mfi to efi
I've been advised to go efi and it wouldn't give me problems vim getting all the set up for 350 should I go for it
Old Feb 6, 2016 | 08:45 AM
Chas's Avatar
Chas
That depends IMHO.
The car may not be starting for a multitude of reasons. If my tank is an original S1 fuel tank it is not baffled. Especially since I have changed to Cosworth brakes and stickier tyres I can stare the fuel pump at just under half a tank. If the car has been run towards empty a few times it would not help the fuel pump. With EFI the matter would be no different.
parso316
Ford Mondeo Including ST
Apr 1, 2018 11:25 AM
Shaunc
Escort Range
May 8, 2016 05:24 PM
simonb33
Feb 23, 2016 08:59 AM
liam-rst
30
Feb 8, 2016 08:18 PM
