New Here Few Photos of My RS
Hi All,
Although a long standing member of the focus RSOC i have recently became a member to come along with a few of you guys "fingers" to the ACE cafe meet i thought i best put up a few photos of the car of which i am sure some of you may already know
I bought it back in 2012 and in that time set about putting my own touch on the car. Its a 2009 on a "59" Mk2 focus RS, and in the time i have owned it, its had a few little modifications, the main being its full "liquid azure blue" respray last year.
Hopefully there are some more mods to come over the course of this year so long as house buying doesn't slow things down to much
Anyway enough of the chat, below are the photos
Chris
upload photo
upload
how to print screen on pc
images hosting
uploading pictures
imageupload
current spec of the car is as below:-
Engine:-
Forged Wisco Pistons and H Section Rods
JWR Stage 2 Camshafts with uprated Springs / Retainers
Flowed and polished head by Harvey Gibbs
Kevlar timing belt
Athena WRC head gasket
ARP head stud kit
Custom built Hybrid Turbo by Harvey Gibbs
Custom painted Anembo inlet manifold
650cc injectors
JWR High Flow RS500 fuel pump
Air / Water Cooling:-
Spec-R intercooler & hard pipes
Spec-R oil breather system / filter housing
Spec-R radiator
Spec-R oil cooler
K&N Extreme air filter with custom AS crossover pipe
Exhaust:-
Full turbo back de-cat Milltek system
Powerflex Exhaust mounts throughout
Suspension / Breaking:-
Custom painted Ksport 380mm super 8 fronts
Custom painted Ksport 330mm 4 pot rears
Full complement of summit chassis bracing
Whiteline rear ARB
A&K adjustable drop links
Hard race lower gearbox mount
Hard race front wishbones & ball joints
Hard race upper and lower rear arms
Hard race upper gearbox mount
BC ER coil over suspension
Engine Dress up:-
Fully painted engine plastics
Spec-R power steering tank
Spec-R water header tank
Roose Motorsport coolant and ancillary hoses
JWR Carbon front strut brace
Exterior:-
Rota PWR 19x9 ET42 bronze
Full Azure blue re-spray
Monkey Wrench custom headlights
All RS logos air brushed
All exterior plastics painted black
Chris
upload photo
upload
images hosting
uploading pictures
imageupload
Engine:-
Kevlar timing belt
ARP head stud kit
650cc injectors
Spec-R radiator
Spec-R oil cooler
Exhaust:-
Whiteline rear ARB
Engine Dress up:-
Exterior:-
Many thanks for all the kind comments. Hopefully following on from the ACE and the meeting of some new faces, I will be able to head out to some other shows with the passion ford guys and gals
Power, as yet i am unsure as it is the 1st Mk2 RS Harvey Gibbs has built however it should be good for around 500bhp although since getting it back last year after the rebuilt its only done about 1500miles so yet to really test it out
Power wise i didnt want to go to crazy, just want it to be a standard Mk2 on steroids as it were.....
Whats power without control! Thats what i always say and those brakes look like good control to me! Then again even if i didn't have the power i would still like to see huge brakes!!
Didn't know it was the first harvey one made. Should last well then, would like to know what it does do if you get it tested. Also 1500 miles is enough to push that right toe down
Then again with that kinda power whats it like for wheel spin on the move?
I will defo put a post up should it be tested, i was hoping to get it upto JWR on the hub dyno over the winter, however with one thing and another i didn't get chance, i know it is currently running a JWR map running around 23psi boost and is a very similar spec to the old JWR demo car other than turbo and that ran 550bhp.
Wheel spin is well, pretty much non existent although i cant deny there is some in the lower gears although less than there was pre rebuild as due to it being a bigger turbo the boost comes in later so makes for a nicer drive
It would be rude for me not to allow you to bring this to our birthday meet on may 21st arnnie so you are officially the 1st person to be given a definate yes on exhibiting your car, see you on may 21st at the ace cafe
original
Feb 4, 2016 04:00 PM
Mungus
Feb 2, 2016 09:27 AM
Bigdaggy123
Ford Focus (All Models)
Feb 1, 2016 03:41 PM
griffo69
Jan 31, 2016 07:57 PM
