Cvh Oil cooler seals
Jan 28, 2016 | 05:04 PM
Are cvh oil cooler seals all
The same as im using a fiesta turbo engine in my xr3i and its defo gone but i can only see them listed on burtons website for S1 and S2 (also dose 2wd yb)
Pic looks the same
Anyone have any ideas??
Jan 28, 2016 | 05:55 PM
Once i went efi I always removed them on Jano's advice, then using a larger zetec oil filter.
Jan 31, 2016 | 01:24 PM
As above I took mine off, I think it's more to heat the coolant up rather than to cool the oil down.
Jan 31, 2016 | 03:40 PM
So just unscrew the fitting in the middle and do away with it?
What do you do with the pipes that connect to it? Connect em together?
Jan 31, 2016 | 09:38 PM
From memory I just fitted a new hose from the T piece on pipe leading from bottom hose to the inlet near the coolant temp sender.
I hope my memory serves me correct, hope it makes sense too.
Feb 10, 2016 | 02:54 PM
You can do away with it if you want mate, I don't often run them when doing ZT installs, but yes the seals should be the same if they are all 1.6 CVH.
May 16, 2021 | 06:26 PM
So i searched this again today as i still haven’t done it and this was googles top result 🤣🤣🤦🏻♂️
siscossie
15
Feb 21, 2016 05:34 AM
SGP
Jan 28, 2016 10:24 AM
tkracing
Jan 27, 2016 04:01 AM
155lee
Jan 26, 2016 10:06 AM
simonmcf
Jan 25, 2016 12:00 AM
